March 9, 2016, 08:37 |
Residual Results Issue
GZY
Rep Power: 10 |
Hi guys,
I have a problem with the output results for Residual. This is compared to the original tutorial results. My simulation had some geometry changes. Steps were done trying to improve the situation. This includes 1. Changing the max inner iteration and stopping criteria 2. Changing the monitor>normalised option from Auto to Off Any inputs from gurus here on solving the issue? The 'Water' readings seemed to be deviating upwards quite a lot. |
March 21, 2016, 22:31 |
LeeTao
Rep Power: 10 |
Hello, elcheapo
Have you tried to decrease the time step? sometimes it can help. Leetao |
March 26, 2016, 13:59 |
GZY
Rep Power: 10 |
Hi Leetao, i somehow managed to observe it to be caused by the overset surrounding thr object. Hence having the entire overset lowered such that it comes into contact with water surface totally solved the issue.
March 27, 2016, 23:14 |
André Luiz Moura Silva Moreira
Rep Power: 10 |
Maybe you may change the under relaxation factor (pressure and velocity) or improve the mesh.
Decrease the time-step is a option too. I'm a new student on CFD, but I could try this. |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 12:12 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
