Surface average on a disc
Old   June 28, 2016, 23:04
Default Surface average on a disc
RenanJ is on a distinguished road
Good night, guys
I am new to cfd and star ccm+, the exercise I was proposed to realize is to find the mean velocity in an area that would be occupied by the propeller under the hull, so I was asked to "capture" the mean velocity in a disk that would be positioned under the hull.
I read some materials and tutorials and I find the "Report > Surface Average" function. If I just creat a derived part (cylinder section), sets the offset to 1 millimeter iex and run the model, would I achieve the proposal of the exercise? the derived part is not a physical element when the simulation is ongoing is it?
Ty for your attention, misters!
RenanJ is offline   Reply With Quote
Old   June 29, 2016, 02:28
kevin alun
marmot is on a distinguished road
correct the derived part is not a wall in the domain, it is just a plane to monitor values or used for scenes,
it seems you understood the exercise
marmot is offline   Reply With Quote
Old   July 19, 2016, 09:50
Sorry for the late reply, I had to take a break for test weeks, I was able to creat the disc but when I run the sim the velocity on the disc is zero, the rest of the sim is working as intended. Those are my settings.
I also got some doubts about the cylinder, If I create a part instead of a derived part but not input it into the boolean subtract will it be a valid part to use when I set my surface average report? because I would be able to rotate it to the desired angle, something I'm not able to do with a derived part and I'm not sure if this will work but I attached the cylinder derived part to the Ship-Csys so when the ship heaves or pitches my disc would still be at the propeller position.
Please give me some advice.
http://imgur.com/a/3cIpc
Average Facet, Surface Vertex or Area-Weighted Emmanuel FLUENT 3 March 27, 2020 10:55
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
need to find the average velocity on a drawn surface mona.16nitr STAR-CCM+ 2 October 22, 2015 00:10
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
How does FLUENT compute the average surface integral ? Andre FLUENT 3 December 21, 1999 10:40
