Changing initial location of - center of mass. |
June 30, 2016, 14:02 |
Ari
Rep Power: 10 |
I am performing DFBI of a catamaran in head seas.I see that center of mass vertical position is the bottom of the hull, where else it should be in a center of hulls depth. How do I change its location? I tried changing it under 6 DOF bodies menu under DFBI. but, can't see any change in the scalar sene. |
July 1, 2016, 02:17 |
kevin alun
Rep Power: 14 |
I know silly question, Did you clear the solution and initialize again after changing the setting?
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
