July 5, 2016, 14:28 |
Suppress output in 'Output' window?
Rep Power: 10 |
Hello folks,
Is there any way to suppress all the messages STAR CCM+ prints in the 'Output' window while it is meshing? and while the simulation is running? I'm using a Java macro to run 150 simulations back- to -back, so I don't want to see all those messages, all I want to see is a message I've programmed into the macro (one message per simulation) Thanks in advance. |
July 5, 2016, 17:10 |
Matt
Rep Power: 17 |
I don't believe that you can do that. You can close the output window all together, but you will need to find another way to display the information that you have programmed in. Without knowing specifics, I would suggest putting an annotation in a scene that updates per your message contents. There may be a way to use the macro to create a field function that defines whatever value you are displaying then create the annotation from that... I have never tried it so it might not be feasible.
July 6, 2016, 01:25 |
kevin alun
Rep Power: 14 |
I also don't believe you can do that, another way could be when you write something from your macro you use a unique word, thus you can easily use the grep command to find your macro output,
sim.println("C1F2D3"+" start geometry change"); sim.println("C1F2D3"+" output pressure drop value"+myValue); when you run in batch also remember to redirect the output to a file, e.g. starccm+ -rsh "ssh" -np 80 -power -machinefile machinesFile -load StartFile.sim -batch Run.java > RunOutput.run |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
Output Window | mosef | STAR-CCM+ | 2 | August 26, 2014 04:28 |
Extracting the output from the FLUENT console window | kesari | Fluent UDF and Scheme Programming | 0 | February 21, 2014 05:37 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
CFX-5: Output in a console window | cfd guy | CFX | 2 | April 24, 2002 08:11 |
