July 8, 2016, 16:32 |
2D ship simulation
Andrea
Rep Power: 9 |
Hi to everyone!
I was wondering if someone can help me. I'm doing a 2D simulation of a ship model hull, in viscous (k-epsilon turbulence model) and unviscous case. The result I want to achieve is the scalar field of velocity and pressure in the two cases and then extrapolate from an XY plot the numerical values of velocity and pressure along the hull, in order to create an Excel sheet. In the unviscous case I managed to have the outcome, but, in the viscous case, when I set up the XY plot for the velocity (X-axis: field function----> position---> X; Y axis: field function---> velocity magnitude) the graphic gives zero velocity for all the lenght of the hull. It's strange, because in the unviscous case the graphic is perfect. (just for info, in the regions--> boundaries---> inlet, I selected, in the velocity node, a costant value (1.9 m/s) , not a field function and in the velocity option,I selected magnitude+direction) Thanks to everyone who will help me! |
July 11, 2016, 04:06 |
kevin alun
Rep Power: 14 |
Perhaps I am missing something here, but I believe for the viscous case the velocity on the hull should be zero, if you want the velocity in the cell-center next to the hull, than create a user field function myCellVelX using $$Velocity[0] and click ignore boundary values and use that for your x-y plot
Tutorial: Heave and Pitch Simulation of Ship hull moving through head sea waves | Baxter | FLUENT | 3 | May 2, 2019 04:31 |
Simulation of flow around a ship hull using fluent and Openfoam | manoj_nav | FLUENT | 0 | December 17, 2015 01:05 |
how simulation ship motion? | esmail | CFX | 5 | May 23, 2015 07:59 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
Wake simulation of ship | sam | FLUENT | 1 | October 10, 2003 02:32 |
