July 19, 2016, 12:46 |
Calculate elongation
André
Rep Power: 10 |
Hi gents,
I would like to calculate a derivative of the velocity field with some sort of field function, however I'm not sure how to calculate it. The quantity is elongation: I know some field functions have the divergence and gradient operators however I would like specific gradients. Any ideas?
Sapere aude! |
July 19, 2016, 17:53 |
Wade
Rep Power: 10 |
You can define your own field function by right clicking the field function node and selecting new. You can then essentially type in the equation you have using the syntax required. Here is a link to the general inputs https://stevedocs.cd-adapco.com/star...298A8=en=.html . There is also a pretty good amount of information on the Steve portal regarding user field functions that you can use.
Last edited by wadeellis; July 19, 2016 at 17:54. Reason: Adding more information |
calculate velocity difference | helly | OpenFOAM Post-Processing | 0 | June 21, 2016 08:49 |
How to calculate the flux of this term grad(alpha1)*alphaf*U? | keepfit | OpenFOAM | 0 | June 6, 2016 10:42 |
Calculate Force Components | Mohinder Suresh | CFX | 2 | October 10, 2015 07:12 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
