July 14, 2016, 05:38 |
Minimum Cell Size
d
Rep Power: 9 |
Is there any way to get the minimum Cell Size of my mesh?
Thanks! |
July 14, 2016, 11:13 |
André
Rep Power: 10 |
You can use the field function of volume to find out which is the smallest one I guess
Sapere aude! |
July 15, 2016, 11:40 |
Andrea
Rep Power: 9 |
yes, go to Continua--->Mesh1 (or the name you assigned to your mesh)--->Reference Values--->Surface Size
July 18, 2016, 05:52 |
d
Rep Power: 9 |
Thanks Andrrrew, but is this correct for my volume mesh cells?
July 18, 2016, 05:53 |
d
Rep Power: 9 |
@acalado, i did a fieldfunction where i took the minimum volume and did volume^1/3 is this correct?
July 20, 2016, 17:08 |
Rep Power: 10 |
The assumption of volume^1/3 is only valid for cube shaped hexahedrals. Even if you are using the trimmer the smallest cell will seldomly be cube but instead one of the trimmed ones. So your expression is only rule of thumb.
What do you need that value for? |
Display Modes | |
CFD-DEM Simulation - Particle Size compared to mesh cell size | 90nash | Main CFD Forum | 5 | November 1, 2018 21:50 |
minimum cell size for time step size calculation | abuabdellah.albatal | ANSYS | 0 | October 22, 2015 17:57 |
Wall Roughness bigger than smallest cell size | Yur | ANSYS | 0 | May 15, 2013 05:20 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
cell size | Baskar | Siemens | 4 | January 18, 2006 14:34 |
