July 31, 2016, 09:49 |
Resampled Volume
Rep Power: 9 |
After creating a resampled volume in derived parts (chosing new scalar displayer), no changes occured on geometry displayer. The resampled volume part created but not visible. Can any one help? I have attached pictures.
August 1, 2016, 06:50 |
Eike
Rep Power: 14 |
AFAIK a resampled volume is not made for using with a geometry displayer. If you want to use volume rendering you should take a look at https://www.youtube.com/watch?v=CH_xJ8la7fI
September 17, 2016, 10:53 |
Shrey Shah
Hello Eike,
I checked out the video but in the video the resampled volume is created using the geometry scene. I am having the same issue as monsha. I create the resampled volume using the same method as used in the video but after applying the scalar field, I cannot see any field like shown in the video. If there is any small mistake that I might be overlooking, can you please guide me or share some documentation related to it? Regards |
September 19, 2016, 00:12 |
Eike
Rep Power: 14 |
Is the representation of the displayer of that scene set to "Volume Mesh"?
September 19, 2016, 03:55 |
Shrey Shah
Yes, I applied the representation as "Volume Mesh" too. It shows the color bar and the values too but does not display the field at all.
September 19, 2016, 06:11 |
Eike
Rep Power: 14 |
Strange. Any clip-plane or clip at the scalar? Did you try to change the colour-bar?
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[Commercial meshers] CuBit | t42 | OpenFOAM Meshing & Mesh Conversion | 6 | July 10, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
