(star-ccm+ 4.02) error during exporting 2d mesh file *.ccm |
May 1, 2009, 05:08 |
Nariman Mehdiyev
Rep Power: 17 |
Hi..
I have some problems about importing the two dimensional mesh. I use STAR-CCM+ 4.02.007 version on the Windows 32-bit platform. I imported the surface (*.igs) to STAR-CCM+. Then, this surface was meshed by trimming method. I convert this 3d mesh to 2d mesh by using default tolerance. This 2d mesh (Mesh Only was selected as Export option on Export File window) was exported as *.ccm for using in other simulation. When I want to import this *.ccm file to STAR-CCM+, I encountered an unexpected error. I tried to import any 2d dimensional mesh which was prepared with earlier versions we got same error. Also I tried to do same procedure with STAR-CCM+3.06.006. There was not any problem. But if I want to import 2d mesh which prepared with STAR-CCM+4.02.007, I got similar error. Have you any experiment about this issue.. is it bug? if you need, i can send the error images, and *.ccm files.. but you can try it with any small cases.. Thanks in advance.. |
May 18, 2009, 19:00 |
Rep Power: 16 |
I think that the ability to import 2D meshes has been removed in the 4.02. It seems the only way to carry out 2D simulations is to import the 3D mesh and convert it to 2D.
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
how to export a mesh from star design to star cd | aounallah | Siemens | 4 | March 6, 2009 06:22 |
Mesh Transfer from ICEM to STAR CCM+ | Waseem Siddique | Siemens | 4 | February 12, 2009 06:02 |
mesh from Star design and use in FLUENT?? | Waseem | Main CFD Forum | 0 | December 17, 2008 06:25 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
