-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   modeling (http://www.cfd-online.com/Forums/star-ccm/64765-modeling.html)
filippo.aero May 23, 2009 11:55
modeling
Hello to everyone, I've made some simulation on star-ccm always modeling the fluid region: i. e. a rectangle with a wing-shaped hole for studing flows. Now I make a more complex wing: how can I make the fluid region around it in star-ccm? I hope you understand my problem... thanks in advance
Maddin May 25, 2009 04:34
When I understand you right you have built a body and around this body the fluid shall flow.
You have to create the "fluid body" - I call it negativ body.
I use Catia for this (bool operator - fast way - maybe somebody knows a faster solution?!).
filippo.aero May 25, 2009 05:57
yes it's right but I'm using proengineer: does it have the same command?
Maddin May 25, 2009 06:01
I don't know. I don't use proE. Maybe your "help" can help you.
I think it should can do the same.
Zolet May 26, 2009 09:45
1. Import the geommetry
2. Representations -> Import -> Create Surface -> Create Block Surface. In this step you will create the "wind tunnel"
3. Wrapp it!
