-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Importing CATIA V5 data into ccm+ (http://www.cfd-online.com/Forums/star-ccm/64799-importing-catia-v5-data-into-ccm.html)
madcfd May 25, 2009 04:44
Do anyone know how to import CATIA v5 data into STARCCM+ ?
In the manual it is stated to download a reader module for CATIA v5 but i dont get it anywhere.
When i import CATIA V5 or any CAD data into starccm+, does the feature lines and curves are already created ??
Maddin May 26, 2009 04:00
For a "direct" use of CCM under Catia you need StarCAT (ask your support - when you have ;) ).
With this "tool" you can make simple simulations with CCM.
For the first try's that's okay.
When you made the tutorial under Catia you should create STL/STEP/IGES or a other format files and this files you can import in CCM.
Create the boundarys is quiet good explained in the manual (I think there was a tutorial for this).
Think you need a "negativ" body, your simulation needs the body where the flow is in to make a calculation. With Catia you can use the boolean operators to create this body, very fast, maybe very dirty but works good.
madcfd May 26, 2009 06:02
Maddin,I undertstand your method. What about using Import surface mesh. i have a option here to import CATIA v5 parts. Can i use this ? At the moment its not working for me.
My interest is to import a catia part and just surface mesh it.so i think this method will appropriate. What do you think ?
Maddin May 26, 2009 06:10
In my CCM the Catia parts don't worked... I tried R15,R16 and R18 with my CCM 3.02.006 (or was it 3.06.002 I don't know...).
Zolet May 26, 2009 09:49
You need a third party license to import catia parts directly to StarCCM+. Contact your agent suport.
Maddin May 27, 2009 03:33
Yeah but could somebody use this successfully?
kurucrown May 29, 2009 21:09
Of course, it works. After you purchase the CATIA native reader license from CD-adapco and install some extra libraries, it works perfectly.
Maddin June 2, 2009 03:10
Hmm I always got an error.
Fex August 1, 2009 08:43
me tooo
i got error too (Return code 104)
did you solve this?
tnx
new usr
f-w August 3, 2009 11:33
If you actually have the extra license to import native CAD, the error can be caused by using a 64bit system.
I was also getting an error on my 64bit system trying to import a SolidWorks part file. But, when I tried it on a 32bit system, I didn't get any errors.
Fex August 4, 2009 03:49
32 bit....i'm sure....not wrking:confused:
