-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Help for parallel session (http://www.cfd-online.com/Forums/star-ccm/64936-help-parallel-session.html)
Fabio_77 May 29, 2009 04:15
Hi everybody,
I need help for parallel in star ccm+.
Someone can give the procedure for work 4 machine in parallel (quadcore, ram 8Gb) in Windows XP.
I recive a message:
"unable to connect" when I try to lunch the parallel session.
Thank you very much
Maddin May 29, 2009 04:33
I hope XP 64Bit?
How do you start your simulation? Can you post the command line here?
Fabio_77 May 29, 2009 04:41
Sure XP 64Bit.
I didn't use the command line, but tried in the program panel (File -> Load Simulation -> Menu parallel).
If you know another way, tell me please, I'm new in star ccm+.
Thank you
Maddin May 29, 2009 06:12
When you do this way you have shown the comand-line below in the dialog.
What parallel options you select?
Do you have enough licenses?
Fabio_77 May 29, 2009 06:22
Yes I have enough licenses.
The option selected are:
"controller on a worker host" and then I set the name of the machine in the "parallel hosts", where I have to specifiy number of processes.
In the line command:
"star ccm+ -server -on NAME HOST : 4"
Maddin May 29, 2009 06:36
I actualy have ccm under linux, but I can look under windows next week.
Under linux I select "Run all processes on local host".
The "controller on a worker host" I only have when I select "specify parallel hosts".
My comand lin ies starccm+ -server -np X (X=numbers of cpu's)
Fabio_77 May 29, 2009 06:40
maybe you work on a single machine with more than a cpu.
I need to work on more machines.
Any suggest? Do you have a user guide?
thank you
Maddin May 29, 2009 06:43
Ahh sure! you have 4 computers with each a quad core :D
Yes I have a user guide, look in your star folder in the doc folder ;)
Or press F1 :D :D
f-w May 29, 2009 16:47
Well, the error says it can't connect, so see if you can even ping the machines (start>run>cmd>"ping MACHINE_NAME").
Then, turn of all the firewalls, and try again. Let us know what happens.
Also, I assume you know that you can run parallel only with machines with same operating system AND architecture (all have to be 64-bit or 32-bit).
