Difference between Volume average and Mass flow average?
Like Tree4Likes
  • 4 Post By fluid23
Old   February 26, 2015, 13:15
Cool Difference between Volume average and Mass flow average?
Sicher Nygren
nygrenm is on a distinguished road
I need help with mass flow average and volume average in Star CCM+. Could someone please help me by explaining what is the difference between the two? I have been doing simulations to see how well they compare to my experimental trials and when I choose mass flow average the numbers are off but with volume average they are almost exact.
The system I am trying to analyze is a plate heat ex changer.
nygrenm is offline   Reply With Quote
Old   March 2, 2015, 13:11
Matt
fluid23 is on a distinguished road
There could be more to it than this, but...
Mass Flow Averaged-
This takes the mass averaged value of a field function on a face. This face can be either a part, region boundary or derived part. What makes it mass averaged is that the value is weighted by the mass flow rate through each cell. It gives a better understanding of the bulk behavior of the fluid passing through the surface.
sum(rho*V*A*<Field Function>)/sum(rho*V*A)
Where rho and V are the velocity and density in each cell of are A comprising your 'surface'.
Volume Averaged-
Takes the average of a field function in a given volume. Here you cannot specify a surface, it has to be an entire volume. This can either be a region or derived part but must be 3D in nature. Here each value of the field funciton is weighted by cell volume rather than by the amount of fluid passing through the cell as before.
sum(vol*<Field Function>)/sum(vol)
Where vol is the volume of each individual cell.
fluid23 is offline   Reply With Quote
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Difference between Mass Flow Average in CFX and Mass-Weighted Average in Fluent dasha ANSYS 0 December 21, 2012 04:41
Volume monitors - Mass or Volume average mag_5 FLUENT 0 March 9, 2010 04:29
average volume flow rate carno FLUENT 0 April 12, 2007 06:37
