Problems with 011
Hey guys,
We updated to 4.02.011, before we had 4.02.007 When I let write a scene in a file after each time step (unsteady sim) then the run takes a time out till I close the CCM. When I have closed it (the GUI, not the run) then it "waits" till I loged in. I had a seen with the courant number. I will try and tell you when it happens with other field functions. Does somebody know if the problem with the mass flow calculation is solved? When you make a CCM V.3 simulation you get a mass flow X. When you start this simulation in V4 you also get the massflow X BUT sometimes you get a massflow Y, when the geometry is different. In front of the courant number I have some meshing problems with easy geomtry. I will make some screenshots and then I post it. The Layer Thickness on Edges is my problem, with Trimm Mesher I get there some adverse cells... Regards |
Scene update problem is a 4.02.011 problem. I tested it.
When you make a run you must have run the GUI on the simulation or it will make a break on the step where you want to have a screenshot. The mesh problem I already have, I only "solved" it with a offset... but not a good soluation in my mind... |
