Surface is not manifold
Old   August 11, 2009, 08:17
Default Surface is not manifold
james charlton
charltonjames is on a distinguished road
Hi, after successfully getting around my free edges problem i have now struck another one when trying to generate a volume mesh. I now get an error stating that the surface is not manifold. I half know what this is, but have no idea what the best solution is to fix this problem. Do you have any suggestions?
Cheers
James
charltonjames is offline   Reply With Quote
Old   August 11, 2009, 08:47
Aroon
vishyaroon is on a distinguished road
Hello Jim,
How many such surfaces do you have? These are because of having more than two surface elements intersecting on a line. If you look into these cells by browsing through the list of surfaces you'll find more than two surface elements (triangles) intersecting on one edge. You may want to delete the unwanted ones.
You can check the surface mesh quality by going into Representations > Surface Mesh. Right click on Surface mesh and select Repair Mesh. This will show you pierced faces, free edges and non-manifold edges and points. It is important to get rid of these 4 surface problems before you proceed with your volume mesh.
vishyaroon is offline   Reply With Quote
Old   August 12, 2009, 11:41
james charlton
Hi, thanks for the help. i have editted my model now, and i have no free edges or non-manifold edges!! However, i have 1 non-manifold vertices and a couple hundred pierced faces. As i still cant generate a volume mesh, do i need to fix these first?? If so, what is the best way?? I have tried to click on auto repair within Representations > Surface Mesh > Repair Mesh, but get an error message about sideness.......
Any suggestions???
Thanks
James
Old   August 12, 2009, 12:14
Aroon
I guess fixing the non-manifold vertices should be similar to fixing the non-manifold edges.
However with the pierced faces can you check if all these faces are lying in the vicinity of one another. I have encountered the sideness error a bunch of times too. It has helped when I decrease the mesh size locally in the region where the surface error occurs. But I'm not sure if that is the solution for it. I think I should also find out the cause of this problem to see why it occurs and that would tell us what to do to fix it.
Old   September 23, 2010, 08:36
Gamer26 is on a distinguished road
Hi everybody.
I am getting the surface is not manifold error message at the beginning of the volume mesh phase. I have tried the repair surface on both my wrapped surface and my remeshed surface. Both have no problems, no non-manifold edges or vertices, free edges, pierced faces etc...
Any ideas?
Thanks
Gamer26 is offline   Reply With Quote
Old   December 3, 2021, 13:48
Default Same Issue
Bal
Bal21 is on a distinguished road
I'm facing the below error. Any suggestion would be helpful?
Originally Posted by Gamer26 View Post
Hi everybody.
Any ideas?
Thanks
Bal21 is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
