Home > Forums > STAR-CCM+
CCM+ system requirements
Old   October 10, 2009, 16:50
Default CCM+ system requirements
Oliver Williams
OJHWilliams is on a distinguished road
I'm about to purchase a home desktop and wish to run CCM+.
I have checked on the CD-adapco website and cannot seem to find the system requirements required to run CCM+.
Does anoybody know what these are??
Many thanks in advance.
O.Williams
OJHWilliams is offline   Reply With Quote
Old   October 12, 2009, 05:25
Bram
bramv101 is on a distinguished road
First: if you need to ask this type of question you shouldn't be doing CAE/CFD..
You CAN run it on a single core cheap PC.
However you SHOULD try to run it on a workstation or server, this is CAE software so it will require a massive amount of resources, unless you want to test a simple AC duct.
My advice go for a 2CPU Xeon systen with the newer 5500 nehalem CPU. Dont be temped to save money on hard drives and memory. Make sure they are high speed
bramv101 is offline   Reply With Quote
Old   October 12, 2009, 11:57
TMG
TMG is on a distinguished road
You need a minimum of 2GB of memory per core. You need enough memory in total to solve the problem you want to solve without swapping. It depends on no. cells, type of cells (hex or poly), solver used (coupled or segregated). Beyond that its mostly about how fast you need an answer, not whether you will get an answer. If you go for a quad core cpu make sure its the latest Intel Nahelem or AMD Opteron as they both scale better than older cpu's. If you aren't working big models, 1 quad and 8GB of memory will do fine with a mid-range graphics card. If you have bigger models then you might want 2 quads, 32GB of memory and a mid to high end graphics card. I just bought a quad core Nehalem with 8GB of memory for about $1200 for home use. The dual quad, 32GB machines, higher graphics card that we have at work go for more like $7k.
TMG is offline   Reply With Quote
Old   October 20, 2009, 05:13
Maddin is on a distinguished road
When you have time to run calulations over night a Quad Core is enough. Most modells you can mesh with 8GB RAM - 7 Million Cells in some minutes are possible.
Maddin is offline   Reply With Quote
Thread Tools
Trackbacks are On
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
system requirements Jaro CD-adapco 3 June 26, 2008 04:33
Need ideas-fuel delivery system Jan NUMECA 0 October 9, 2006 04:30
Need ideas-fuel discharge system Jan Main CFD Forum 0 October 9, 2006 04:27
System Requirements Christoph Gebhardt (Gebhardt) OpenFOAM Installation 1 February 3, 2005 08:30
