November 2, 2009, 15:51 |
Wrap surface
Jaime Saelices
I need to solve a hydrodynamic problem without symmetry. So i create a block volume as control volume with the hull inside this volume.
When I begin meshing I do not know how to maintain the hull in the mesh because the hull disappear from the mesh. Selecting the wrap surface is in largest internal but other options doesn`t work. Does anybody know how to work with this kind of geometries (control volume + complex surface for external flows simulations)? Thanks! |
November 11, 2009, 08:26 |
Custom size the mesh in your hull geometry.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
