February 21, 2013, 14:45 |
Multi computer parallel job
Jonny
Rep Power: 16 |
I have a question regarding parallel running of Star-CCM+ cases.
Is it possible for me to connect together 2 or more computers through a simple LAN hub and use the CPUs from both machines to solve the case? I have the relevant parallel Star licenses. Would it be possible to set up one of the machines to hold the licenses and the second machine just checks out licenses for the cores as it needs them? Thanks |
February 22, 2013, 02:27 |
siamak rahimi ardkapan
Rep Power: 17 |
It is possible but I think it is not easy. If you are very good in IT issues then you can do that. Otherwise you need to ask an IT guy.
Good luck Siamak |
February 22, 2013, 02:54 |
Jonny
Rep Power: 16 |
Thank you for your reply siara.
Do you mind expanding on your post, what will be likely issues? |
February 22, 2013, 03:02 |
Rep Power: 17 |
Dear Jonny,
If you have installed STAR-CCM on your computer you may find the file Flex license administration guide. It is a PDF file located in the subnode CD-adapco in All programs. Open it and search for network in the text, you will find very useful information in detail. I hope it can help. Good luck
Good luck Siamak |
February 22, 2013, 08:44 |
anonymous
Rep Power: 13 |
I do not have the pdf file with the details in. Would it be possible to detail the steps that I would need to take?
thanks |
February 27, 2013, 03:34 |
Melih Meriç
Rep Power: 15 |
Hi Badger,
If you already use STAR-CCM+, you have the pdf what you need. Follow the path that i gave and search "Using a Remote Multi-Core Workstation" in user guide and then also you will find various commands and tips for this. C:\Program Files\CD-Adapco\STAR-CCM+7.04.006\doc You can do it same Operating system and with same machine name/identity. By the way there is an answer related this issue. May be you can do more wide search in forum. |
Partitioning problems in the parallel job | Neo | FLUENT | 5 | January 26, 2021 10:10 |
how to hook UDF to a parallel job?? | gandesk | FLUENT | 0 | December 15, 2010 23:30 |
How to save images of contour plots during parallel job | Neil11 | FLUENT | 5 | September 23, 2010 19:06 |
running fluent parallel with MS job scheduler | Shamoon Jamshed | FLUENT | 0 | November 15, 2009 12:48 |
RE: Parallel job in Vista-32 | Kevin | FLUENT | 1 | July 11, 2008 12:22 |
