November 15, 2009, 10:07 |
modeling of slosh analysis with time varying accel/decell
joy
I am trying to model some sloshing analysis in a fuel tank of an marine engine. I want to give accel/decel which is varying with time.
In reference values i was able to give constant accel/decel but not varying. I will be thankful if some one can provide me solution. Last edited by mohan makana; November 15, 2009 at 10:27. Reason: delete |
November 25, 2009, 01:06 |
Ping
Rep Power: 20 |
Two suggestions:
1. very easy method - simply type an equation into the gravity setting for X (ie replace 0 with say sin($Time * 3.2) or whatever. 2. easy method - create a field function called say GravX, and set its value to the required equation - eg sin($Time * 3.2). Then simply type this field function name into the gravity setting for X (ie replace 0 with $GravX). Even thought lots of menus dont have a field function dropdown and only constant settings, you can still type in a field function name or equation - very handy and not well documented! 3. harder method - do a java macro and solve via the macro changing the gravity constants every timestep. |
How to convert model from Gambit to Star CD ? | Jimmy | Siemens | 4 | September 16, 2008 10:07 |
can we model incylinder flows STAR CCM+ | farhath | Siemens | 2 | July 8, 2008 15:00 |
how to make animation in star ccm *NM* | raziftech | Siemens | 3 | October 17, 2007 02:35 |
STAR, Fluent, CFX and conj. heat transfer | star-user | Main CFD Forum | 8 | January 21, 2003 00:07 |
Radiation in STAR | fluent user | Siemens | 4 | October 11, 2001 16:12 |
