December 3, 2009, 04:08 |
extract and export data for each time step
Thomas
I want to extract results from a derived plan at each time timestep and export it to one or more files. The data should be read later by MATLAB so I don't think that I can use the auto export function because I can't export it in a format MATLAB can read.
I have no problem exporting the results for a single time step to a .csv file as long as the calculation is not running. Any suggestions? |
December 9, 2009, 09:50 |
Dalibor
Try with: File -> Auto Export
December 14, 2009, 12:17 |
Just got the same problem. Also i don't know how to read ".ccm" format from auto-export.
December 18, 2009, 12:10 |
unsteady simulation data
Subhadeep
I know of Tecplot360 have an add on package for StarCCM+ unsteady data that could handle this.
I looked at it a bit but could not use it as StarCCM+ was installed on a cluster for me and the Tecplot360 was on a WN based univ desktop comp. To have all the .ccm files read into the system having Tecplot360 was impossible due to data storage. So if anyone has used this add on successfully let me know so I can at least have the confidence to do it in future if the two are on the same system. Otherwise its a bit tedious for StarCCM+ unsteady simulation to have a time averaged results like TKE or Reynolds stress. If you look at the field functions for DES, LES these quantities don't exist and one has to write the primary variables out and do the time ensemble averaging outside StarCCM+ environment |
December 21, 2009, 07:29 |
Dalibor
If you first crate the Report (and the Monitor) with data you want to monitor (choose trigger before you run), then run your case and after that, open the monitors end export it in *.csv format.
January 18, 2010, 08:25 |
#6 | |
Thomas
Until now I have solved the problem by writing a java-script which takes a single time step and exports a table containing only the data I want. |
June 25, 2010, 08:03 |
LES-Calculation
Valentin Mayer
Hello Thomas,
I read that you find a way to write the needed quantities for each time step. I'm really interesting about this tool - i'm doing my diploma thesis - and I will do my simulation with LES. Wich programm do you use for the analyzing the values? - Matlab? or direct in ccm+? Do you compare you LES calculation with some exp. data? Are the results good? I would very hapy if you can give me some advises using LES. Thank you Valentin |
June 26, 2010, 10:11 |
LES-Calculation
Thomas
Since I was not able to use the auto-export function to export data in ascii-format I created a table with the data I was interested in. It is possible to export table data to a .csv file. To be able to export the data for each time step i made a macro which calculates a single time step and the exports the table.
You can make most of the macro directly in CCM+ by using the record button, but you need to make a loop around the commands by yourself afterwards. I used MATLAB for analysing the data. I only needed a mean velocity and a standard deviation of the velocity. The values should be compared to some experimental results, but I ended up only using RANS-approaches for the comparison. Therefore I do not have a lot of experience using LES. |
March 19, 2015, 15:58 |
Nom
Hello Thomasbl
I am running a simulation in which I would like to record datas at given positions (line probe) for each time step. You said you wrote a Macro, but I have no clue how to write in Java... Could you share you script to record datas at each time step ? Thank you very much ! |
March 19, 2015, 17:35 |
Matt
I don't think you need a script for that. I could be wrong. You should be able to write a table with the results directly to your hard drive for each time step, iteration or whatever. Look at xyz internal tables. I think you just have to select your line probe as the input part then select the scale quantities you want to write to file. Never actually tried it though.
March 19, 2015, 18:15 |
#11 |
Nom
MBdonCFD
In deed, there is a way: create a report at each time step of the values of the paramaters I want to store at different line probes. However it creats: a csv file at each time step for each line prob. I have 10 line probs, I am targeting 80 time steps. It means I will end up with 800 files... I wish I could have all the informations stored in one single csv file to make post processing easier ! |
March 19, 2015, 18:22 |
#12 |
Matt
I see. Yeah that would be tedious. You could always just write a matlab script to read and sort the data. Probably just as easy to modify a macro recording though.
Good luck. |
August 2, 2017, 06:57 |
#13 | |
Rep Power: 9 |
How did you create a table? Just a table with pressure and volumetric flow rate measured at different iterations.
auto export, export |
radial turbine data export question | ally | CFX | 0 | September 14, 2005 15:10 |
Variable value with time - from SOLVER FILE | Tuks | CFX | 4 | July 11, 2005 05:49 |
Post-process: how to extract Graph Registers' data | Jiaying Xu | Siemens | 11 | July 17, 2002 04:38 |
