Largest Internal Volume does not exist. Try reducing the smallest relevant volume |
December 14, 2009, 11:43 |
I was doing the basic manifold meshing tutorial supplied with CCM+ ver 4.04.011 and got the following when trying to wrap the surface:
Wrapper::generateOctreeMesh: Largest Internal Volume does not exist. Try reducing the smallest relevant volume or reducing refinement sizes. Can anyone help me out here, is this a user induced error or a problem with the program. |
December 14, 2009, 12:02 |
I reduced the gap closure size to 50% of base size and now it completes the wrapping, is this because i had holes in my surfaces then?
I noticed a couple of small holes afterwards but i didnt think this would produce a server error????? |
December 14, 2009, 13:13 |
I think that you didn't close the manifold inlet pipe part well. It's not easy to click where you want all the points so rotate the geometry to see if it's really closed
December 14, 2009, 13:40 |
March 16, 2019, 16:35 |
Enric
I agree with robinfisichella, what you have to do is to reduce the mesh dimensions of the Surface Wrapper. i.e. changing base size, or reduce directly the gap closure size.
Thanks robinfisichella! |
August 16, 2021, 07:48 |
Rep Power: 4 |
Hey
I have the same problem, getting the same error when I want to execute mesh, I changed the Gap closure size but did not work, do you have any other recommendation ? many thanks |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
