solid region empty or not?
Old   December 27, 2009, 16:26
Default solid region empty or not?
Francesco
Trofrensis is on a distinguished road
Hi
I'm sorry for the question, these are the first times i approach the cfd simulation.
I have realized a model of heat shield for a exaust pipe.
I made two regions: a fluid and a solid .
My question is for the shield that belong two the solid region .
You can immagine it as a semi -shell that is close in eash side by boundaries belonging to solid region.
When i make my volume mesh and then i make a section it seems to be empty inside . It's normal? Becouse monitoring the section temperature during simulation , I can't understand if inside is empty or not.
I set parameters like thermal conductivity inside the continuum , but I've seen you can set it also in the interfaces. So i think that the first is for the material inside the solid continuum ,while the second is only for the contact interface with fluid (air) region ? Is that correct?
Trofrensis is offline   Reply With Quote
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
Treatment of solid region in collocated grid Yongpan Cheng Main CFD Forum 0 December 10, 2006 22:27
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
