solid region empty or not?
Old   December 27, 2009, 16:27
Default solid region empty or not?
Francesco
Trofrensis is on a distinguished road
Hi
I'm sorry for the question, these are the first times i approach the cfd simulation.
I have realized a model of heat shield for a exaust pipe.
I made two regions: a fluid and a solid .
My question is for the shield that belong two the solid region .
You can immagine it as a semi -shell that is close in eash side by boundaries belonging to solid region.
When i make my volume mesh and then i make a section it seems to be empty inside . It's normal? Becouse monitoring the section temperature during simulation , I can't understand if inside is empty or not.
I set parameters like thermal conductivity inside the continuum , but I've seen you can set it also in the interfaces. So i think that the first is for the material inside the solid continuum ,while the second is only for the contact interface with fluid (air) region ? Is that correct?
thank you
Trofrensis is offline   Reply With Quote
Old   January 7, 2010, 08:35
abdul099 is on a distinguished road
hi
I think, that's correct. You can specify a thermal conductivity inside the continuum, but also on the interfaces. It is used, if you want to add an additional thermal conductivity. For example, imagine a plane fuselage. To consider the effect of the external flow on the internal themal field, you can specify the additional thermal conductivity, so you don't have to simulate the external flow.
But i'm sorry, i couldn't understand your problem with the emty region. Maybe you could post an image?
regards
abdul099 is offline   Reply With Quote
solid region empty or not? Trofrensis STAR-CCM+ 0 December 27, 2009 16:26
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
