INTRODUCE A MACRO FOR AVOID SMEARING IN VOF in ccm+ |
March 4, 2010, 05:09 |
davide
" The numerical accuracy of the VOF method depends highly on the interface resolution. To prevent the solution from becoming too smearing due to numerical diffusion, a compression procedure is developed to perform VOF interface rescaling such that the average thickness within the interface (0.1 < alfa < 0.9) is kept constant through out the computation. The interface et solution compression procedure is expressed as: alfa_new = Max{0, Min[ 1, 0.5+ f(alfa_old-0.5)]} and f= (Interface Thickness)_new / (Interface Thickness)_initial " by Yen-Sen Chen, Huan-Min Shang and Paul Liaw Engineering Sciences, Inc. Huntsville, AL 35802 I wonder if it's possible to implemet and how it is possible to write a routine to do that in CCM+ Thank you very much |
March 11, 2010, 11:52 |
Smearing
Rep Power: 16 |
Hi
The VOF scheme in STAR-CCM+ uses the HRIC (high resolution interface capturing scheme), by its nature it shouldnt smear the interface unless perhaps you are running with very large timesteps. Have a look at the online help & search for HRIC |
smearing vof, vof |
Display Modes | |
Doubt about F_FLUX(f,tf) macro & VOF ?!!!!!!!! | asghari | FLUENT | 2 | October 28, 2012 04:03 |
Problem of smearing vof air-liquid | lupoigloo | STAR-CCM+ | 0 | November 30, 2009 12:27 |
