inital conditions
Old   April 21, 2010, 08:33
Default inital conditions
Johannes
jopawipr is on a distinguished road
Hey everybody!
I desined 3 eulerian phases(Dodecane(L),Dodecane(G) and Nitrogen).
At the beginning of my simulation there is just Dodecane(L) and Nitrogen.
So how can I define where the inital position of the phases are?
It's a 3dimensional simulation. The inital position just depends in z direction.
So for example:
z<=0.5 --> Nitrogen
z>=0.5 --> Dodecane(L)
Can anybody help me?
thank you very much!
Johannes
jopawipr is offline   Reply With Quote
Old   April 22, 2010, 09:20
Vinicius Girardi
Vinicius is on a distinguished road
Hi Johannes,
You have to create a scalar field function such as:
Initial Nitrogen:
($$Centroid[2] < 0.5 ) ? 1 : 0
Initial Dodecane:
($$Centroid[2] > 0.5) ? 1 : 0
at the Volume Fraction node, select it to composite and associate these field functions for each phase.
You can also use the $$Position field function instead $$Centroid. Be sure that you mesh has a good quality in this region, and if possible, try to have the cells aligned in the division line.
Regards,
Vinicius
Vinicius is offline   Reply With Quote
Old   April 26, 2010, 07:22
Johannes
Thank you very much for your answer!
But for what is the "?" in the equation?
And the [2] is for the z-axis?
Best regards,
johannes
Old   April 26, 2010, 07:25
Vinicius Girardi
The ? in the equation is the "if" condition, for example (condition) ? true : false.
The axis are x =[0], y=[1] and z=[2].
Vinicius
Old   April 26, 2010, 08:10
Johannes
thank's a lot!
a last question:
Does it matter i which order I define the three eulerian phases?
Cause i still get a failure when I define Dodecane(L) and Nitrogen with a field function. The initial condition of Dodecane(G) is 0 and constant...
Thanks, and best regards
Old   April 26, 2010, 08:56
Vinicius Girardi
The order that you create the phases just define the order you might input the data in some fields, like volume fraction... What is the error that appears?
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
