Meshing error
Old   June 8, 2010, 12:29
Default Meshing error
Matt Lynam
Mlynam is on a distinguished road
I am getting an error when attempting to re-mesh my surface and create a volume mesh. The error reads:
orientFaces: Sidedness had an error
has anyone seen this error? I am running version 4.06.011 and using the polyhedral, prism layer, and surface remesher for the model. Any help would be appreciated.
ML
Mlynam is offline   Reply With Quote
Old   June 8, 2010, 16:01
Vinicius Girardi
Vinicius is on a distinguished road
Check if your imported surfaces doesnŽt have pierced faces or other errors. Maybe youŽll need to use the surface wrapper tool.
Vinicius is offline   Reply With Quote
Old   June 8, 2010, 17:20
Matt Lynam
I did inspect the original surface and I couldnt't find any pierced or strangley formed geometry. Also - surface wrapper is out of the question as I have multiple regions in the geometry. Thank you for your reply, do you have any other ideas?
ML
Old   June 8, 2010, 18:06
Vinicius Girardi
You said you have multiple regions, are they already set or you will split by surface topology to create the interfaces?
Old   June 9, 2010, 12:20
Matt Lynam
They are already set and the interfaces have been created.
ML
Old   June 9, 2010, 13:07
f-w
f-w's Avatar
f-w is on a distinguished road
The wrapper can be used on multiple regions if "per-region meshing" is checked in your mesh continua; you won't have a conformal mesh at the interfaces as a result, though.
f-w is offline   Reply With Quote
Old   June 9, 2010, 17:55
Matt Lynam
Ah! I have a mesh. Thank you for your help everyone!
ML
Old   July 6, 2010, 09:47
abdul099 is on a distinguished road
Maybe you want to tell us what the cause for the problem has been? It could also help other users with a similar problem...
Best regards,
abdul099 is offline   Reply With Quote
Old   July 8, 2010, 13:16
Matt Lynam
abdul099,
I believe I was having the issue because I was applying a single mesh continuim to multiple regions. When I applied the "per-region meshing" option I no longer had the problem. Does that help?
ML
Old   November 29, 2011, 15:47
TrII4d is on a distinguished road
@ Mlynam and abdul099
yes that was the reason. I had the same problem as u abdul099.
I activated "per-region meshing" and now star ccm+ mashed.
thank you so much!
greetz
TrII4d is offline   Reply With Quote
Old   January 2, 2012, 14:29
Mgolse is on a distinguished road
Per region meshing works but if I would like a conformal mesh at the interfaces this will not suffice.
Mgolse is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 silent_missile OpenFOAM Installation 5 August 10, 2007 07:31
