Home > Forums > STAR-CCM+
Setting Gravity for Convection
Old   June 21, 2010, 07:27
Default Setting Gravity for Convection
James Lamb
James Lamb is on a distinguished road
I am modelling the passive cooling of a heat sink in an enclosure. I have created a volume of air with a stagnation inlet below and a pressure outlet above. When setting gravity in this model it creates a large flow downwards. I expected to see buoyancy forces at work on the hot components, this does not seem to be the case. Am I not leaving the simulation long enough or could I need more inner iterations? At the moment I am running for a minute with 2 inner iterations per second.
Thanks for the help in advance.
James
James Lamb is offline   Reply With Quote
Old   June 21, 2010, 10:00
Vinicius Girardi
Vinicius is on a distinguished road
Are you using the coupled solver?
Vinicius is offline   Reply With Quote
Old   June 21, 2010, 10:05
James Lamb
Not at the moment no.
Old   June 21, 2010, 10:11
Vinicius Girardi
Try to use the coupled solver and use more inner iterations, maybe you also can check your time-step, you should have a compromise between your time-step size and your number of inner iterations...
Old   June 21, 2010, 10:13
James Lamb
Ok just re-meshing now with a coupled solver. Thank you for your help
Old   June 22, 2010, 02:30
Maddin is on a distinguished road
Look at your courant number.
Maddin is offline   Reply With Quote
Old   June 25, 2010, 11:49
WhoAmI is on a distinguished road
To see the gravity effects, your reference density should be really really close to the density of the fluid at that temperature. Make sure the difference between reference density and density less than 1e-7.
WhoAmI is offline   Reply With Quote
Old   June 25, 2010, 13:20
Jipp or some steady tests before to check the density "effect" - with and withput gravity.
Or what do you think?
Old   June 25, 2010, 14:27
After initializing the solution, write a filed function to calculate the difference between the density in a cell ($Density) and the reference density value. Create a scene with this field function to see the density difference. Then try to readjust the reference density value (and also the value in field function) to make the difference as small as possible.
Thread Tools
Trackbacks are On
Cells with t below lower limit Purushothama CD-adapco 2 May 31, 2010 21:58
Gravity setting giogio FLUENT 1 March 22, 2008 18:48
Warning 097- AB CD-adapco 6 November 15, 2004 05:41
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
Setting Outlets with gravity.. Javier Larrondo Phoenics 0 January 17, 2001 11:15
