July 4, 2010, 01:41 |
Intake manifold analysis
Hi,everyone,I have encountered a problem while running an analysis for an intake manifold in star ccm.the error message I received was as follows: And in the residuals window, all the residuals show solution divergence during the first iterations. Below is my model information: Geometry dimension:unit mm Inletiameter:27àoutlet:ares:380,length:70 àsection of pipe: ares:820 ,length:105; mesh models: surfaces remesheràpolyhedral mesheràprism layer mesher reference values: base size:5 àprism layer thickness:2.5àrelative minimum size(surface size) :1à relative target size(surface size) :2àothers:default physical models: 3DàstationaryàsteadyàIdeal gasàsegregated flowàstandard k-Epsilon tuberlenceàhigh y plus wall treatment, click on incompressible in the ideal gas property window. Reference values:deault Initial conditions: Pressure:750pa(half of the pressure difference between inlet and outlet) àturbulence length scale:2 mmàturbulent intensity:0.04àothers:default Boundary conditions: Inlet:stagnation . total pressure:1500pa.Outletressure out pressure:0pa. other parameters keep as initial conditions. |
July 4, 2010, 14:32 |
Vinicius Girardi
Try to run some iterations using a velocity or mass flow rate at the inlet. It's better if you know one of these values. Then just go back to your pressure-pressure condition.
July 6, 2010, 04:00 |
Rep Power: 18 |
Ramp the pressure...
intake manifold simulation | uday | Main CFD Forum | 6 | December 21, 2009 01:39 |
need help with manifold analysis in fluent | anil1886 | FLUENT | 0 | August 29, 2009 10:29 |
Intake manifold analysis | mehndan | Siemens | 3 | August 22, 2008 04:24 |
Intake manifold analysis | mehndan | Main CFD Forum | 6 | July 3, 2008 05:28 |
Modeling of a airflow in a intake manifold | Jack | FLUENT | 1 | September 21, 2003 22:22 |
