Mesh Reference Values problem.
Old   July 19, 2010, 04:11
Unhappy Mesh Reference Values problem.
rezki
rezki is on a distinguished road
I want to create the following example of the tutorial:
Training Guide > Meshing Tutorials > Control Valve Meshing Tutorial.
When I arrived at Setting the Global Mesh Reference Values step :
(Training Guide > Meshing Tutorials > Control Valve Meshing Tutorial > Polyhedral Meshing Exemple > Setting the Global Mesh Reference Values)
I could not to change mesh Reference values
For example, I could not introduce the value of 4.0 into: Prism Layer Thickness > Relative Size > Percentage of Base, a value of 33.3 is always imposed and it remains unchangeable.
Please,
What can be reason for that ?
Best regards
Rezki
rezki is offline   Reply With Quote
Old   July 19, 2010, 04:19
bengy is on a distinguished road
hmmm 1-st: relative to base ->percentage of base, then your prism layers will be "percenatge" depend. 2-nd: change relative to base->absolute size and then add your constatnt value
bengy is offline   Reply With Quote
Old   July 19, 2010, 05:02
rezki
Thank you very much for your help.
Ok, but in the tutorial, they recommended to use relative to base.
The parameters which will be used for this meshing tutorial are here:
Reference Node Name
Property Name
Value
Base Size
Value
0.06 m
CAD Projection
Project to CAD
true (default)
Number of Prism Layers
2 (default)
Prism Layer Stretching
1.5 (default)
Percentage of Base
4.0
Surface Curvature
# Pts/circle
36 (default)
Surface Growth Rate
Surface Growth Rate
1.3 (default)
Surface Proximity
# Points in a gap
2.0 (default)
Surface Proximity
Search Floor
0.0 (default)
Surface Size > Relative Minimum Size
Percentage of Base
4.0
Surface Size > Relative Target Size
Percentage of Base
8.0
Tet/Poly Density
Growth Factor
1.0 (default)
Tet/Poly Density
Density
1.0 (default)
Tet/Poly Volume Blending
Blending Factor
1.0 (default)
Best regards.
Old   July 19, 2010, 05:09
ok, I agree, but what do you do when you want to have 6 mm prism layer thickness ( how many percentage ?? ) ? I think that better way is using absolute size and have maximum control of prism layers thickness
regards
Old   July 19, 2010, 05:12
rezki
Ok, but in the tutorial, they recommended to use relative to base instead absolute.
Base Size > Value > 0.06 m
Prism Layer Thickness > Relative Size > Percentage of Base > 4.0
Surface Size> Relative Minimum Size > Percentage of Base> 4.0
Surface Size > Relative Target Size > Percentage of Base > 8.0
Best regards.
Old   July 19, 2010, 05:15
rezki
Best regards.
Old   July 19, 2010, 05:16
I give up so maybe other will help you
best regards
Old   July 19, 2010, 05:30
rezki
Hi
I don't know why several answer are create , I have just seen that. I am really sorry.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
The problem with GAMBIT - using two mesh sizes. Owen FLUENT 2 June 22, 2005 05:16
Mesh Mignard FLUENT 2 March 22, 2000 05:12
