Home > Forums > STAR-CCM+
Mass Flow Rate Not Available?
Old   July 11, 2010, 23:10
Default Mass Flow Rate Not Available?
trex930 is on a distinguished road
Hi all,
Im trying to obtain the mass flow rate of an exhaust that im simulating. However, when ever the report runs, it just says
Note: Field funciton mass Flow Rate is not available inside Region 1 for smoothing. Using zero except at boundaries where it is defined.
Has anyone encoutered this issue before?
Heres the background of my project.
I have an nozzle spraying upwards into an 'ejector' to the right of the nozzle, there is a long tube, and at the end of the exhaust and the tube, I put two large boxes and set one face boundary to free stream. Does that seem correct to anyone?
Thanks in advance,
T
trex930 is offline   Reply With Quote
Old   July 12, 2010, 10:41
Aroon
vishyaroon is on a distinguished road
Are you trying to get the mass flow rate in a plane section or some derived part that you have generated? If you are trying to plot the mass flow rate for this part then the warning is generated.
vishyaroon is offline   Reply With Quote
Old   July 14, 2010, 01:37
New Question! Didnt want to bombard this forum with another thread.
I was curious as to what parameter in StarCCM+ controls the Tdr.
I ran a simulation with decent results, but then i run it on a similar geometry and the Tdr goes all haywire! The two geometries are VERY similar. And I dont understand whats going on!
And lastly, the Residuals given in StarCCM+, are they absolute or relative residuals??
Old   August 10, 2010, 21:04
Can anyone help me out?
Old   August 11, 2010, 08:21
Vinicius Girardi
Vinicius is on a distinguished road
The residuals are normalized... if you wnat to see the absulte, go to the monitors folder and at each monitor change the normalization option to Off..
Vinicius is offline   Reply With Quote
Thread Tools
Trackbacks are On
Mass flow rate eddie FLUENT 12 August 12, 2014 09:15
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
Mass flow rate Siang FLUENT 1 December 23, 2003 03:47
