Prism Layers in the corner
Like Tree3Likes
  • 1 Post By Maddin
  • 1 Post By rwryne
  • 1 Post By rwryne
Old   July 19, 2010, 04:27
Default Prism Layers in the corner
bengy is on a distinguished road
hello,
how to improve prism layers in the corner? I mean what I should do to create prism layers which are not convergent in the corner. I have very good mesh so informations and tips from help doesn't work (it works only for poor quality mesh).
bengy is offline   Reply With Quote
Old   July 21, 2010, 02:55
Maddin is on a distinguished road
Show a picture plz.
Maddin is offline   Reply With Quote
Old   July 21, 2010, 03:18
Default I have some problem with this case
that's it.......
Old   July 21, 2010, 05:06
You can't do anything. Support also didn't know a work around...
I had the same problem...
Jihun, Lee likes this.
Old   July 21, 2010, 06:34
yeah that's true - support also didn't know. it's very strange so I decided to concentrate mesh closely to boundary (between prism layers and core mesh)
Old   July 31, 2012, 05:35
Default Prism Layer Crossover
djack is on a distinguished road
Hi everyone,
I'm meshing a container using star ccm trimmer and prism layer model.
I'd like to know if it was possible to crossover two different prism layer in a corner to increase mesh definition in that region.
If possible that may be a solution for bengy
thanks,
Djack
djack is offline   Reply With Quote
Old   July 31, 2012, 05:59
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I think if you reduce the prism layer stretching in the mesh/reference values/prism layer stretching, you can have finer meshing.
siara817 is offline   Reply With Quote
Old   July 31, 2012, 08:50
Ryne Whitehill
rwryne is on a distinguished road
Originally Posted by bengy View Post
that's it.......
Are you using 7.02 or 7.04? If so, try using the "advancing layer mesher". It is a new meshing model that will handle those corners better. read about it in the help file, they have screenshots of a Poly+Prism vs Advancing Layer for very similar geometry.
pooya_1375 likes this.
rwryne is offline   Reply With Quote
Old   July 31, 2012, 09:03
Ryne Whitehill
Here is a quick example I made comparing the two....I did exagerate the prism layer thickness to highlight the differences.
Old   July 31, 2012, 09:07
I'm using 6.04...
Anyway thanks for the answer.
djack
Old   July 31, 2012, 09:18
Ryne Whitehill
Originally Posted by djack View Post
I'm using 6.04...
djack
We don't get to say this often, but try coarsening your grid. It seems to happen as a function of OverallHeight / Surface Cell Size. Just keep increasing your surface cell size until the problem goes away, and then see if this is an acceptable size....if not, try decreasing your overall prism layer height.
Old   August 16, 2012, 15:38
eRzBeNgEl is on a distinguished road
the new mesh type advanced layer meshing is the solution for this problem
eRzBeNgEl is offline   Reply With Quote
Old   August 17, 2012, 03:38
I never heard about that mesh type. Is it available in Star ccm 6.04.
Djack
Old   August 17, 2012, 08:40
Ryne Whitehill
Djack
It is the same mesh type I was referring to in my posts from 3 weeks ago, and it was introduced in 7.02 and improved in 7.04
Old   December 10, 2012, 15:26
I'm now using starccm 7.06 and as you said it works !
Thanks you all,
Djack
Old   December 14, 2012, 20:34
abdul099 is on a distinguished road
The main question is: Why do you think, this mesh would be bad in the corner?
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   December 17, 2012, 03:43
I see two arguments :
- Actually the velocity magnitude in the corner is smaller than far from the corner, then the solution may be to increase the prism layer height in the corner (law of the wall). That's definetly not the case for the old prism layer meshing system where the prism height was decreasing.
- I guess it's better to keep the same prism layer structure when geting closer to the corner.
Old   November 7, 2013, 08:12
renee is on a distinguished road
I know this topic is a bit old but I am currently facing the same problem.
My Prism Layer Setup results in the same way bengy posted with his picture above. I did a short mesh study by variing different values. So far it looks like my prism layer thickness is to high.
Can somebody please explain me why the weird corner prism layer structure could cause a lower mesh quality? Sure, the y+ value should be constant but the y+ is only dependent on the first layer hight which not too much affected as you could see in the picture bengy posted.
Thanks a lot in advance.
Rene
renee is offline   Reply With Quote
Old   July 7, 2016, 15:46
Default Similar Problem at Trailing Edge of Airfoil
  #19
ibrababz is on a distinguished road
I have a similar problem at the trailing edge of an airfoil.
The prism layer (which needs to be this thick) horribly converges at the tail of the airfoil.
I have even disabled the prism layer at the trailing edge and only applied it to the main body, but it still does not change the strange convergence.
A picture is attached.
Any potential solutions?
Thanks,
Ibrahim
ibrababz is offline   Reply With Quote
Old   August 1, 2016, 06:46
Eike
Eike is on a distinguished road
Maybe you should consider a small radius at the edge.
There is a workshop "Near Core Layer Aspect Ratio" (STAR-CCM+ 11.02) which could help. The topic is to improve the mesh/prism-mesh of a turbine blade.
Eike is offline   Reply With Quote
[ICEM] Surface/Volume orientation errors growing prism layers jlichtwa ANSYS Meshing & Geometry 17 September 25, 2018 00:41
[ICEM] Prism layers around interior wall rwryne ANSYS Meshing & Geometry 18 February 1, 2013 10:57
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 09:13
