-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Vortex Shedding (http://www.cfd-online.com/Forums/star-ccm/78474-vortex-shedding.html)
Nikhil Kumar July 22, 2010 12:32
Vortex Shedding
I've beent rying to model flow over bluff object to observe vortex shedding but havn't been able to achieve it. I only get one vortex at the beginning and then the system goes into steady state. I used 'Implicit unsteady', 'k-epsilon', 'RANS' and default settings for the time steps. The other parameters are as follows,
Velocity - 10m/s
PipeDiameter - 0.5m
Cylinderdiameter - 0.2m
Can anyone tell me where the problem might be?
nomad July 23, 2010 13:01
The default time step is too large. Your mesh might be too coarse.
coolio July 26, 2010 05:07
Hi!
Fisrt : check if under implicit unsteady you are using the second order scheme discretization!
Second: Check if the lateral boundaries are periodicities!
Third: Estimate the frequency of vortex sheding based on the Strouhal number (0.21) and set the time step to be at the most 1/10 of the computed period!
Regards!
Vinicius July 28, 2010 13:25
Also use LES or DES. RANS methods are not very suitable since your time step is to small...
Nikhil Kumar December 7, 2010 11:17
Thank you all for the reply.. I got it...
