Star-CCM+ 32 in W7 64
Old   July 26, 2010, 18:45
Default Star-CCM+ 32 in W7 64
mdominguez is on a distinguished road
Can you help with this question.
If run the 32bit CCM+ in W7/64 I can use a big swap file than the 4 GB limit for 32 bit O.S., this help me with message "Insufficient virtual memory".
Itīs correct.
Thanks, Marcelo
mdominguez is offline   Reply With Quote
Old   July 26, 2010, 19:20
Tom Keheley
TomK is on a distinguished road
Will not help. The error message you are getting says that all physical memory is being used and more virtual memory is necessary. Only two solutions for this - add more physical memory or increase virtual memory (swap space). Be aware that while adding swap space may work, it will slow the analysis down significantly, because now you have I/O to contend with. Your quick option is to decrease the cell size.
Tom
TomK is offline   Reply With Quote
Old   July 26, 2010, 20:12
Thanks Tom.
New question. If have 12GB RAM in W7/64.
Is possible run CCM+(32b) in W7/64 using all the memory ?
Best regards, Marcelo
Old   July 27, 2010, 19:22
Tom Keheley
I don't think so. 32 bit systems are set up to use only 4 gig memory (XP will only address 3.5 gig). Since you are running a 64 bit version of WINDOWS 7, why not use the 64 bit version of CCM+? It is available from CD-adapco's download site. I have 64 bit WINDOWS 7 and the 64 bit CCM loaded on my laptop. It has 8 gig memory. I just completed a job with 6.1 million cells with no problem. It is easy to install.
TomK
Old   July 27, 2010, 20:44
Thanks again, Tom.
Old   July 29, 2010, 11:57
Default Full Capacity
rpravata
RobertoPravata is on a distinguished road
Hello everyone,
I have a problem with my Star CCM + 64 bits
It only uses 6% of full capacity. How I can fix it?
I have version 4.4.1911
RobertoPravata is offline   Reply With Quote
Old   July 30, 2010, 07:52
Robert
RobertB is on a distinguished road
Why not use 5.04 ? Works fine on my Windows 7 64 laptop.
RobertB is offline   Reply With Quote
Old   July 31, 2010, 11:19
Maddin is on a distinguished road
@Roberto: Too small Swap file? Then limits windows the virtual space...
32 Bit can only handle 2GB per thread - run parallel to use more. Mesh per region, split the regions etc.
Maddin is offline   Reply With Quote
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
A genearl question on STAR CCM nstar STAR-CCM+ 5 June 24, 2009 09:39
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
Star CCM - Problem with image hardcopy quality James Siemens 2 March 14, 2007 02:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
