July 26, 2010, 18:45 |
Star-CCM+ 32 in W7 64
Can you help with this question.
If run the 32bit CCM+ in W7/64 I can use a big swap file than the 4 GB limit for 32 bit O.S., this help me with message "Insufficient virtual memory". Itīs correct. Thanks, Marcelo |
July 26, 2010, 19:20 |
Tom Keheley
Will not help. The error message you are getting says that all physical memory is being used and more virtual memory is necessary. Only two solutions for this - add more physical memory or increase virtual memory (swap space). Be aware that while adding swap space may work, it will slow the analysis down significantly, because now you have I/O to contend with. Your quick option is to decrease the cell size.
Tom |
July 26, 2010, 20:12 |
Thanks Tom.
New question. If have 12GB RAM in W7/64. Is possible run CCM+(32b) in W7/64 using all the memory ? Best regards, Marcelo |
July 27, 2010, 19:22 |
Tom Keheley
I don't think so. 32 bit systems are set up to use only 4 gig memory (XP will only address 3.5 gig). Since you are running a 64 bit version of WINDOWS 7, why not use the 64 bit version of CCM+? It is available from CD-adapco's download site. I have 64 bit WINDOWS 7 and the 64 bit CCM loaded on my laptop. It has 8 gig memory. I just completed a job with 6.1 million cells with no problem. It is easy to install.
TomK |
July 27, 2010, 20:44 |
Thanks again, Tom.
July 29, 2010, 11:57 |
Full Capacity
rpravata
Hello everyone,
I have a problem with my Star CCM + 64 bits It only uses 6% of full capacity. How I can fix it? I have version 4.4.1911 |
July 30, 2010, 07:52 |
Robert
Why not use 5.04 ? Works fine on my Windows 7 64 laptop.
July 31, 2010, 11:19 |
Rep Power: 18 |
@Roberto: Too small Swap file? Then limits windows the virtual space...
32 Bit can only handle 2GB per thread - run parallel to use more. Mesh per region, split the regions etc. |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
A genearl question on STAR CCM | nstar | STAR-CCM+ | 5 | June 24, 2009 09:39 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
Star CCM - Problem with image hardcopy quality | James | Siemens | 2 | March 14, 2007 02:36 |
