July 28, 2010, 10:43 |
Surface Integration
Amir Ali
Hi friends
I am simulating a heat spreader for electronic cooling. The surface area of the spreader is 20mm x 20mm.Using heat transfer report I can determine the total power dissipated from the spreader surface. My problem is I need to choose part of the surface (ex area 1mmx1mm) and determine the power dissipated from that area. I tried derived parts and generate section but nothing comes out it is always zero. Any body can help? |
Display Modes | |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Numerical integration of 'T' across a 3D surface | ACFD-student | Main CFD Forum | 5 | March 23, 2006 15:51 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
