Splitting regions
Old   September 25, 2010, 10:44
Default Splitting regions
Steve
king_steve is on a distinguished road
Hi all,
Ive imported a surface mesh of a complex piping system in star ccm+. When i import the model to star ccm+, the program automatically creates approximately 1000+ regions and boundaries. The regions are too small and thus ive decided to import the whole geometry as a single region and split it afterwards. However again when i try to split it (by angle) i end up with the same problem i.e. thousands of regions and boundaries.
The model contains 2 inlets and 20 outlets and i would like each of these inlet/outlet regions to have their own independent boundaries. What is the easiest way to do that?
Kindly revert back soonest as i have to hand in the report asap.
Thanks in advance.
King_Steve.
king_steve is offline   Reply With Quote
Old   September 27, 2010, 12:48
John
nomad is on a distinguished road
If you're splitting by feature curves, then use only the feature curves where you want to split the regions, ie, edit feature curves, then create new feature curves from the existing ones where you want your regions to be.
nomad is offline   Reply With Quote
isolated fluid regions were found alfin CFX 14 October 8, 2015 01:36
flux splitting emrah Main CFD Forum 3 August 30, 2014 08:53
Flux splitting Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 19 January 9, 2013 04:07
Connect 2 Regions Marc_r OpenFOAM 2 April 19, 2010 13:27
[Other] Importing regions from 3rd party meshing programms suitup OpenFOAM Meshing & Mesh Conversion 1 November 10, 2009 09:40
