Star crashes when visulising Mesh
Hi all,
I've recently installed Star on my laptop to allow me to work off campus, I've just found today however that when I try and apply a surface or volume mesh representation to a displayer the programme shuts down (no errors or warning messages, just closes). The server is left running in the back ground to reconnect to. I have updated to the latest graphics card drivers to attempt fix the issue though it still occurs. Has anyone else experienced this/ can help out? Thanks Dan Chambers |
In the scenes tab, try right clicking and click on apply representation. That was my work around...
Alternatively save the file and restart as a last ditch solution? Good luck |
Just given your suggestion ago mate but unfortunately it doesn't make any difference :( . Can't really under stand what could be causing it other than the laptop graphics being in sufficient
a workaroud is (assuming you have winxp) 1) display proprieties 2) settings 3) advanced 4) troubleshoot 5) set hardware accelleration to NONE of course you have to do this before laucing starccm. hope it helps. |
Cheers mate, \i'll try it and see if it works. Need to find another way of disabling hardware accel unfort as the ATI drivers don't allow you to do it easily!
Just use an Nvidia Quadro card. Even small ones like 570, 580 or 380 are fine.
I think, I've heard from our supervisor something like "Star-CCM+ doesn't like ATI graphics cards". The first time I was laughing, but when I was starting working at home, I got the same strange "shutdowns" of the gui when working at home. And I own an ATI graphics card.
My friends found exactly the same thing with his ATI graphics card.
Luckily I've managed to solve mine by modifying the driver to allow it access to more video memory (shared memory for the laptop) which has solved it. I suspect it was crashing as there wasn't enough memory to render the grid |
It seems like you guys have this figured out but I just wanted to reaffirm one solution to the issue.
I had this exact same problem with an ATI graphics card and after troubleshooting with cd-adapco tech support we determined that it was the graphics card and they recommended switching to an Nvidia Quadro. I switched to the Quadro 1800 and haven't had a problem since. I have also used it on the Quadro 570 and 580 and, albeit slow, I haven't had those crash either. I hope this helps anyone else with a similar problem searching through these forums. -Brendan |
