How to automate geometry, mesh and case setup using starccm+
Old   January 25, 2011, 05:30
Default How to automate geometry, mesh and case setup using starccm+
James Willie
jwillie2000 is on a distinguished road
Hi All,
I am new to starccm+ and wanted to know whether it has a scripting language like ANSYS does with the journal file to automate the process of geometry and mesh creation and setting up a simulation? In it does it would be nice to know how can learn this as quickly as possible.
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
Old   January 25, 2011, 08:32
Chenthu is on a distinguished road
Originally Posted by jwillie2000 View Post
Hi All,
Thanks!
Jimmy
Yeah it has..in the form of macro's which is based on java....just start macro to record ur actions and then later use it to automate the same process...
Chenthu is offline   Reply With Quote
Old   January 26, 2011, 03:17
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Note however that while recording and replaying java macros does work, it implies that all the models require exactly the same initial state for the process to work correctly. For a robust and more general solution, you'll need considerably more effort.
olesen is offline   Reply With Quote
Old   January 26, 2011, 11:13
Pauli
Pauli is on a distinguished road
I concur. In principle Java macros work. In practice, any deviation from what you recorded instantly becomes an exercise in patience, perserverance, and computer science.
Pauli is offline   Reply With Quote
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
