Problem Concerning free surface wave simulation
Like Tree1Likes
  • 1 Post By michaels
Old   February 17, 2011, 08:47
Default Problem Concerning free surface wave simulation
michaels is on a distinguished road
Hi Everyone,
I got a problem concerning first order VOF waves in STAR CCM+.
Iīve created a plot for the free surface elevation, saved pictures after every time step and ticking through the pictures i recognized that the waves travel up and down as a group. They keep their form and donīt break or something, they just travel up and down periodically.
Any ideas why thatīs the case? Could it be a problem due to false BCīs?
My BCīs are velocity inlet where the waves enter, pressure outlet where they exit, both with field functions for e.g. hydrostatic pressure.
the sides are symmetry planes, the bottom and top also velocity inlets. I also tried bottom as wall and top as symmetry plane and both as symmetry plane which made no difference.
Another problem is that thereīs a reversed flow at the outlet boundary, which doesnīt seem to affect the waves, since they donīt pile up or something. Does a reversed flow mean ther is something false?
Which BC's would you use?
Iīd appreciate any advise.
Regards
Michael
Bulava likes this.
michaels is offline   Reply With Quote
Old   February 24, 2011, 14:19
Vinicius Girardi
Vinicius is on a distinguished road
Are you simulationg just the waves, without any body inside?
If you are expecting the waves breaking, you must use 5th order waves. the first order are a poor approximation and are not adequate for this.
Regards,
Vinicius is offline   Reply With Quote
Old   February 25, 2011, 03:18
the first trials are just the waves without any body...the aim is to monitor forces/pressure on a floating body later on. my wavelength is 1.72m and the amplitude 0.0565m.
would you use any kind of current or wind properties to eliminate the reversed flow output?
Old   February 25, 2011, 08:28
Vinicius Girardi
You should user velocity inlet in all your external boundaries, except in the outlet. You can also use the wave damping to avoid the waves reflect in the outlet boundary...
Take a look at the tutorials in the training guide.
Regards
Free surface problem: hull mesh questions albertofast OpenFOAM 2 December 15, 2010 20:50
Zero Volume Fraction in Free Surface Problem marega CFX 1 September 10, 2009 07:31
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 02:20
Help needed with free surface simulation Mark CFX 4 October 27, 2006 13:07
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 16:56
