Impose transeint force
Old   March 3, 2011, 16:52
Default Impose transeint force
Henry Arrigo
Henry Arrigo is on a distinguished road
How can I impose a sinusoidal force on a body. In the external force node there is no possibility to bind a Field function. What s your suggestions please?
Thank you.
Henry Arrigo is offline   Reply With Quote
Old   March 3, 2011, 16:54
Henry Arrigo
any one can help me please?
Old   March 3, 2011, 23:29
alastormoody11 is on a distinguished road
If the field function is not available you need to write a macro.
A simple strategy is to record a macro where you set a value for the external force with a numeric value.
Use this macro as a initial construct and instead of the numeric value replace it with your function.
alastormoody11 is offline   Reply With Quote
Old   March 4, 2011, 09:07
Henry Arrigo
thank you
this is not gonna work since I need to impose a continuous force while this case would result in a discrete one. more over I want to come up with solution in a single run.
Old   March 6, 2011, 23:28
As long as you are using CFD for your simulation you cannot apply continuous force.
Whatever you do, even if you manage to get your BCs via a field function you will be using a finite time step and hence your profile will always be implemented in discrete time steps and not in a continuous fashion as you have envisioned.
So the only remedy to the above problem is to use a smaller time step while applying the acceleration profile.
Hope you got that
Old   March 7, 2011, 09:01
Henry Arrigo
Thank you Alastormoody.
Did you mean applying acceleration to the fluid field? Did I get it right.
In the wall node and in the Physics Conditions sub-node, there is an option which is named Tangential Velocity Specification. It has this possibility to use a field function as a vector field. Have you ever use that? I guess that could be a remedy too...
Thanks.
Henry
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 20:43
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
pressure force and viscous force CFD FLUENT 0 March 7, 2006 01:03
