Multi-element airfoil
Old   March 6, 2011, 16:33
Default Multi-element airfoil
Aaron Long
aaronlong is on a distinguished road
I'm new to CFD and I'm running a 2D multi-element wing in STAR-CCM at various angles to measure the lift and drag coefficients. I have tried using different meshes and I have been unable to get the results and stall point to match with previous results.
I am using a k-epsilon turbulent, consent density model.
What can i change to give me accurate results?
aaronlong is offline   Reply With Quote
Old   March 6, 2011, 16:42
Aaron Long
I forgot to mention that the wing is in air at 30 m/s
Old   March 15, 2011, 19:36
John
nomad is on a distinguished road
From my experience with multi-element airfoils, kepsilon gives a more accurate Clmax, but doesn't indicate stall angle correctly, whereas the transition model seems to predict stall angle correctly but underestimates the Clmax.
I don't think there is anything out there available commercially that does a good job of predicting stall, but I could be wrong.
nomad is offline   Reply With Quote
Old   April 1, 2011, 07:47
PB4
PB4 is on a distinguished road
also, stall means flow separation which I gathered from these forums makes the problem unsuitable for 2D, you should work in 3D instead.. but my experience in CFD is very low I stand corrected..
PB4 is offline   Reply With Quote
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 11:29
Modelin Multi Element Airfoils Yashwant Ganti FLUENT 0 June 5, 2007 03:50
multi element airfoil data shadi memarpour Main CFD Forum 0 June 20, 2004 04:33
Multi Element Airfoil J.Dumas Main CFD Forum 2 May 13, 2000 07:24
