Which AMG Linear Solver
Old   March 11, 2011, 09:42
Default Which AMG Linear Solver
Tom Schmitz
Zuixy is on a distinguished road
Hey,
I have a problem with solid body and a fluid flow. I use a segregated Solid Energy Model for the solid body. My Problem is that the temperatur changes just very very slowly. There a no big temperature changes due to the fluid. Any suggestions how i can improve the solver?
Thx
Zuixy is offline   Reply With Quote
Old   March 14, 2011, 02:41
alastormoody11 is on a distinguished road
hi,
the AMG linear solver just solves the simultaneous algebraic equations obtained after discretization, changing it not going to affect ne thing.
If your simulation is giving wrong results you need to check the simulation setup and not be concerned the linear solver.
If you provide some more data regarding your simulation setup maybe someone can help u.
alastormoody11 is offline   Reply With Quote
Old   March 14, 2011, 03:43
Tom Schmitz
Thx for the answer. I didn't get wrong reluts and i could fix the problem by doing more iterations. Due to the fact that i'll have to calculate some variations i thought i could improve the speed a bit.
But another thing:
I want to calculate the heat flux over the outer cover of a cylinder.
1. I was using a Area Averaged Report with the Boundary Heat Flux field function over the interface. The result was zero.
2. I tried the same but with a cylinder section which had a smaler radius as the cylinder. The result was also zero.
3. I tried a heat transfer report over the interface. It was also zero.
After that i thought about the reason and got two ideas.
1. It is to small to be calculated.
2. There is something wrong with the interface. But what? I impried the bodies as i designed and the In-place Interface was created by StarCCM.
Do you have any idea where the problem could be?
Old   March 14, 2011, 03:51
To increase the speed with which your solution converges you might try by increasing your under-relaxation factors
Old   March 20, 2011, 10:24
willimanili is on a distinguished road
Try to optimize your initial settings close to the solution you expect, that should improve your speed, too.
willimanili is offline   Reply With Quote
Fluent IcePak - AMG Solver Russ FLUENT 2 December 31, 2018 09:57
AMG solver _divergence detected Shamoon FLUENT 6 March 11, 2009 07:59
Linear system solver elias FLUENT 0 November 19, 2008 09:30
Error: divergence detected in AMG solver: temperat Rubén FLUENT 3 December 11, 2007 11:48
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
