Home > Forums > STAR-CCM+
Meshing and running Problems
Old   April 27, 2011, 11:16
Question Meshing and running Problems
Mintsa Andre
mintsa_icsd is on a distinguished road
I have some problems, i want to simulate a complete solar collector, but when meshing my geometry I got many cells with negative volume. How I can fix it?
secondly, when I run my simulation, I got an error '' reversed flow, and limited temperature in X cells''. Can you help me, please.
PS: I use StarCCM+ 6.02 and StarCCM+ 5.07
mintsa_icsd is offline   Reply With Quote
Old   April 28, 2011, 01:02
alastormoody11 is on a distinguished road
Regarding the meshing, have you checked whether your surface mesh is ok?
You can do this by going in representation, click on the initial mesh/remeshed surface depending on whether you are using the surface remesher and say repair surface. When you do so STAR will show you the problems with your surface mesh rectify them before creating your volume mesh. There might be a problem with pierced faces.
Regarding the solver problem, what you are specifying, is it an error or a warning? If it is a warning, you need not worry about it unless the warning persists over a large number of iterations. If it persists you would need to check your simulation setup to ensure that there are no mistakes.
alastormoody11 is offline   Reply With Quote
Old   April 28, 2011, 17:09
abdul099 is on a distinguished road
The reversed flow might be due to a pressure outlet boundary used as an inlet or due to a backflow through the pressure outlet. The fist one is o.k., the second one is suspicious and should be checked.
The temperature corrections are very suspicious, that shouldn't occur for more than a few iterations when convergence is good. If it persists, you should check your mesh quality. I assume, that could be the problem, because you got negative volume cells. That shouldn't be when meshing goes well.
abdul099 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Parallel meshing + simulating. need Help nicolarre OpenFOAM 2 April 11, 2011 11:04
problems in meshing sudden expansion and contraction with hex thinktank ANSYS Meshing & Geometry 4 June 16, 2010 16:05
Meshing 3D AHU room khimkhim ANSYS Meshing & Geometry 3 November 4, 2009 12:26
Surface Repair for Meshing Andy R Main CFD Forum 13 May 3, 2008 14:33
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
