Slow calculation
Old   May 12, 2011, 11:57
Smile Slow calculation
Tom Janda
tom.j.87 is on a distinguished road
Hi, I have one question.
My computer is have: 2 cores (Pentium i3, 8gb ram). Now I count the calculation with 1 200 000 cells. One iteration takes 1 minute, but all the calculation takes 3 days. I compute with settings Run mode: Serial. CPU usage is 30%, 60% of RAM. I using as a client Windows 7 and version Star CCm 4.04 64bit. My teacher say me that I have change settings from bios: Hypertreading turn off. It seems to me that both cores are not loaded at full power. Thanks for your answer.
Regards Tom
tom.j.87 is offline   Reply With Quote
Old   May 16, 2011, 02:25
Matthias Fitl
MFitl is on a distinguished road
Good Morning,
Regards Tom
  1. You need to start the paralell mode to use more than one core. You need either a HPC license or a second starccm+ license to do so.
  2. It is recomended to use n-1 cores for performance reasons. (n = number of cores available on computer)
  3. wit more the 1e6 cells and only 8GB RAM you will run into swaping leading to very poor performance, especially on Windows.
Conclusion: Setup a 4-8Core (!Licenses for starccm+) 16-32GB Ram fast harddisk system. If you or someone in your next to you is familar with Linux I would prefere to use this at leats for the server procves, but this is only a little bit more than personal experience. And I do not want to start a Linux-is-better-than-windows-or-the-other-way-around-war, defenetly.
CU,
Matthias
MFitl is offline   Reply With Quote
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Defining output as input for second calculation mannobot FLUENT 1 June 2, 2010 04:20
very slow calculation speed, any sugestions? Duncan Gravill Main CFD Forum 3 March 29, 2007 16:38
Warning 097- AB Siemens 6 November 15, 2004 04:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
