May 29, 2011, 23:02 |
Mesh issues
Hi Guys,
I just meshes a bundle (full of pipes) but the skewness angle are around 95. Those bad cells are located on the walls outside the bundle as illustrated in the picture. The geometry is also shown in the picture. What should I do? I've refined the whole bundle by decreasing the base size of the mesh a lot (four times, every time decreasing by a ratio of 1.3). The problem is still there. Thanks for your help! Famerfamer |
May 30, 2011, 06:34 |
Instead of changing the base size which will lead to a large increase in the cell count, you can try putting the pipes creating problems in different boundaries by splitting them interactively and then set smaller custom surface sizes, so that those areas are captured by means of local refinement.
May 31, 2011, 15:31 |
#3 | |
Is there any difference if I use volumetric control to only refine those walls where those bad cells are located? I mean to use a very thin block to cover those walls. But I'm not sure if only by refining walss the problem can be solved. How do you think? Thanks, Famerfamer |
May 31, 2011, 17:02 |
#4 | |
May 31, 2011, 17:53 |
#5 | |
Thanks for you help. Famerfamer |
June 1, 2011, 10:38 |
You're right... I try to refine those walls and there has already been 11Million surface meshes generated which is toooo large for a volume mesh...
Help... Does anyone have a good idea? |
June 8, 2011, 21:41 |
Dave
You could try repairing the base surface either with the surface wrapper or manually (it's a pain, but sometimes and hour of geometry clean up can save you a week of meshing). A lot of times the a poor underlying geometry can make a mess of things (trailing edges on wings, stl files, etc). The manual repair feature is found by right clicking on the import tab of the "representations" directory. Hope this helps
[Gmsh] Issues with mesh tolerances after using gmshToFoam | madad2005 | OpenFOAM Meshing & Mesh Conversion | 1 | August 20, 2014 05:10 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
