August 14, 2011, 20:10 |
Pressure monitor for single points
Rep Power: 15 |
Hey all,
Is there anyone who knows how to set up pressure monitor for a single point? I know I need to create a report and then get a monitor and plot. But the problem is which value I need to choose when I create the report, maximum, surface average or something else? Since I'm monitoring pressure value for a single point on a wall of a reator or vessel, surface average isn't correct. Furthermore, I need to monitor 4 diffrent points located on the same wall. I'm trying to plot the pressure of each points as a fuction of iterations. Thanks! |
August 14, 2011, 21:49 |
Ping
Rep Power: 20 |
create a derived part of type Probe, Point at the required location. Then create a report with that part. A Max report will be fine of any field function.
August 26, 2011, 23:03 |
Rep Power: 15 |
That's the way I did with and successful now. Thanks, Ping!
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 20:05 |
pressure in Natural convection??? | engahmed | FLUENT | 0 | June 14, 2010 12:51 |
pressure inlet & outlet. help ASAP Plz | engahmed | Main CFD Forum | 0 | June 13, 2010 15:34 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Setting pressure and velocity in inlet | Asghari | FLUENT | 5 | September 22, 2006 13:23 |
