HI Every body
Old   August 19, 2011, 19:42
Default HI Every body
Zawar Idrees
zawar is on a distinguished road
I am designing a double pipe heat exchanger in which hot water is passing through the inner pipe and phase change material(Paraffin) is present in the outer pipe.I make my design in 3-D and I used two seperate meshes for both the pipes.I dont know which physics values are used for inner pipe as hot water is passing through the inner,when I used the melting/solidfication option,it doest work.I also define the interface between the two pipes.Both pipes are made up of copper.I dont know how to assign phase change material in the outer pipe and either it will be solid or liquid.I also see the tutorial for melting/solidfication tutorial in the help option of Star CCM,but cant find any solution
I will be very thankful, if any body help me for solving this problem
Thanks
Waiting for someone response
zawar is offline   Reply With Quote
Old   August 28, 2011, 05:30
abdul099 is on a distinguished road
Set up a physics continuum for every material (liquid for the inner pipe and VOF with melting / solidification for the outer, like in the tutorial). Maybe you have to include the solid material, the copper of your pipe. (would have it's own physics continuum)
abdul099 is offline   Reply With Quote
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 8, 2016 23:10
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
Body in windtunnel - high preassure behind the body? Andyjoe OpenFOAM 4 February 16, 2010 10:57
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
