Request for memory failled
Old   August 12, 2011, 06:12
Default Request for memory failled
Bullet Tooth
Bullet Tooth is on a distinguished road
Hi everyone,
I am facing a problem while running my simulation. In fact when the computation generates more than 700000cells I am having an error "A request for memory failed. This is typically due to insufficient virtual memory". Is there any thing to do in order to solve the problem?
Thanks
Bullet Tooth is offline   Reply With Quote
Old   August 15, 2011, 00:25
Ping
ping is on a distinguished road
close all other programs, better still reboot and only start STAR-CCM+ and Task Manager, then keep an eye on its memory use.
Increase your Base Size by a factor of 10 to start with and see if it meshes and solves, then try to go smaller. The wrapper can use more memory than other mesh models, which normally use much less than is required for the solvers. 2GB RAM should be fine for about 1M poly or hexa cells depending on what physics are enabled. Also never use tet mesh unless you want to double memory use and solve 5+ times slower for equivalent accuracy.
ping is offline   Reply With Quote
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 09:37
Request for Book online is equivalent to piracy Noname Main CFD Forum 20 July 4, 2005 18:39
Memory request Giovanni Siemens 1 September 10, 2001 12:21
