Converge problem
Like Tree5Likes
  • 1 Post By abdul099
  • 3 Post By JBeilke
  • 1 Post By Paulh
Old   August 12, 2011, 04:42
Unhappy Converge problem
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Hi All,
I want to simulate air movements in a room.
I have a converge problem. Also I got this error "BiCGStab did not converge !"
in the residual page, Tdr in k-epsilon diverge. Do you know how to solve the problem?
the surface mesh quality is higher than 0.5 and volume mesh quality is higher than 0.1.
Thanks in advance for your help
siara817 is offline   Reply With Quote
Old   August 12, 2011, 04:53
eRzBeNgEl is on a distinguished road
1. Idea: maybe use 1st order and increase in later steps to 2nd order
2. 2. Idea. Use k-omega SST Model
eRzBeNgEl is offline   Reply With Quote
Old   August 12, 2011, 06:43
Default Thanks for the reply
siara817's Avatar
I did the ideas. But they did not change the result. I tried other turbulent models but the results were not better than the first one.
Thanks again for your reply
Old   August 12, 2011, 07:35
I assume u r running a steady simulation......just give the implicit unsteady a try....
I know this is very general, but maybe it works....
Old   August 19, 2011, 07:16
siara817's Avatar
I tried as you said.
I changed the initial conditions and it improved the convergence, but still I can see some fluctuations after 60 iterations.
I will try to improve the quality of mesh to see if it can influence.
Best Regards
Old   August 19, 2011, 18:50
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
increasing the mesh quality is generally a good idea.
you might also try to check where the simulation diverges.
also try to reduce the underrelaxation factors.
sail is offline   Reply With Quote
Old   August 29, 2011, 07:17
well, at least check your geometry and your interfaces. There might be somethwing wrong.....
Old   September 3, 2011, 07:51
abdul099 is on a distinguished road
High mesh quality does not mean, the mesh is good for this problem. Is it fine enough?
Is the room closed? I mean, totally enclosed by walls? Do you run compressible or incompressible?
abdul099 is offline   Reply With Quote
Old   November 15, 2011, 17:32
Maybe a little bit too late, but it might help other people with the same issue.
It seems, the message just means, the AMG solver for one equation did not reach it's convergence criteria. I would ignore the message as long as the residals don't behave weird and the result is fine.
By the way, it's not critical when a residual goes a little bit up as residuals in Star-CCM+ are normalized.
Balele likes this.
Old   November 15, 2011, 18:45
Joern Beilke
JBeilke is on a distinguished road
"BiCGStab did not converge !" means, that the calculation stops. So it does not really help to ignore the message ;-)
I got this error when I tried to run an airbag gasgenerator simulation with realgas and a mixture of different species. The only way to overcome the problem was using the coupled solver.
JBeilke is offline   Reply With Quote
Old   November 16, 2011, 17:34
It does not mean, the calculation stops. It means only the AMG solver could not reach the convergence criteria within the defined number of steps and the residuals didn't go down anymore. But you don't know anything about the difference. For example, the convergence criteria for the AMG solver is 0.1 (which is the default setting), but it reaches only 0.10000001 within the (default) 30 steps - you will get the "BICGStab did not converge" message, although there's nearly no difference in the solution.
Old   November 16, 2011, 18:05
Joern Beilke
At least my testcase stops when I get this error:
A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide."
andrei1585, anon_l and Aeromidd like this.
Old   November 16, 2011, 18:57
Yeah, but the reason why it stopped was the floating point exception. That's somehting completely different. A floating point exception always means the simulation stops, and it can also occur without ever using BICGStab.
Also you can get a non-converged BICGStab without getting a floating point exception, that just depends on your physics.
And it doesn't harm to read more carefully. I've written "I would ignore the message as long as the residals don't behave weird and the result is fine."
Old   November 17, 2011, 13:47
Default Bi Conjugate Gradient Stabilized not converging
  #14
Paul Hancock
Paulh is on a distinguished road
The online documentation indicates that BiCon is a solution acceleration method for the AMG solver. Turn it off.
This message started to appear in some of my cases in v6.04 - I haven't made the switch to v6.06 yet. Siara817, what version of the code are you using?
siara817 likes this.
Paulh is offline   Reply With Quote
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
converge problem snowshovel CFX 13 January 18, 2007 21:05
Converge problem of 3D free jet flow Jen FLUENT 11 January 24, 2005 00:21
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
