June 22, 2010, 07:02 |
How do you set up a porous region
james charlton
Rep Power: 16 |
Im a little confused on how to correctly set up a porous region. I know how to create a porous region. But im confused on what interface i should use (porous baffle?), Also how do you calibrate the settings - i.e. to have a 50/50 and 70/30 porous region? Any advice would be appreciated. regards James |
June 25, 2010, 02:11 |
Rep Power: 18 |
Read the manual.
It's very simple! Maybe you have to read the expression more than one time but with a little excel sheet you can set the pressure drop you need. |
June 29, 2010, 10:17 |
james charlton
Rep Power: 16 |
Thanks Maddin, but by the manual, do you mean the help files?
I've looked there and no luck. Any chance you could expand you answer |
June 29, 2010, 10:20 |
Rep Power: 18 |
No the help files are only a "little" manual.
You should have some pdf-files in your ccm directory. 2000 pages strong... there you find all you need! |
June 29, 2010, 10:27 |
james charlton
Rep Power: 16 |
ah...... i didnt know this existed. Thanks maddin.... this could answer several of my questions!!! (i hope)
July 5, 2010, 08:00 |
Re:Porous
Niaz Ali Ahmed
Rep Power: 15 |
There is a tutorial called Porous Flow. Go to Help>Training Guide. You may use an In-Place interface too.
July 5, 2010, 08:19 |
james charlton
Rep Power: 16 |
Thanks Niazaliahmed - I am using In-place interfaces now. I have a volume mesh and porous region. I just dont know what to do then - i.e. in the physics values in the porous region. I see there is a porosity setting (constant) which as default is set at one. I've tried changing this value to numerous values between 0 - 1.0 but nothing seems to work.
- I have tried the tutorial If i apply the same process - i.e. Axisymetric Tensor; and random Pi and Pv values i do get a result. But i cannot validate this process or values or the accuracy of the given results. Any further suggestions would be gratefully appreciated. |
July 5, 2010, 11:11 |
Vinicius Girardi
Rep Power: 17 |
The value of porosity just have effect when you are running unsteady simulations, if you are running steady, just set the Porous Inertial Resistance and Viscous Resistance.
July 5, 2010, 11:15 |
#9 |
james charlton
Rep Power: 16 |
@Vinicius - Thank you. Thats fine. So i guess the next question is which Tensor you use? Following this i need to establish accepted values for initial and viscous resistance for trees.
July 6, 2011, 17:39 |
#10 |
Rep Power: 15 |
Hey James,
Given a geometry, how to create a porous region from it? Thank. |
July 6, 2011, 17:44 |
#11 |
james charlton
Rep Power: 16 |
Sorry, i dont understand you question.
July 7, 2011, 05:54 |
#12 | |
You've to choose the tensor according the flow direction in the porous region and its geometric characteristic. you have to know if the porous region is isotropic un-isotropic, axial-symmetric etc. For Inertial and Viscous resistance values you must have a characteristic curve (velocity/DP or similar) of the considered material. If you need further help please describe your problem in detailed way by |
July 15, 2011, 14:15 |
#13 |
Rep Power: 15 |
I mean do you know how to create a porous region including boundary and interface? Currently I have three parts vertically connected to each other, say A, B and C. B is the porous region which is sandwiched by A&C.
I just have no idea how to set B as a porous region and what parameters I need although I've read through that porous region tutorial... Any help would be appreciated. |
August 13, 2011, 18:29 |
#14 | |
Rep Power: 15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
Porous region set | braket | FLUENT | 4 | November 18, 2010 02:09 |
How to set BC for flow through porous plate | TypeSpeed | FLUENT | 0 | January 21, 2010 09:14 |
turbulence model for porous region | Nina | CFX | 1 | June 11, 2008 13:05 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 10:15 |
